Although I mainly monitor the Wisconsin side of things.)))
Ok well as we're going to find out from people who are trying to actively listen in MN, that things gradually get locked out for one reason or another. Usually its the same reason, with a million different convenient excuses. I speak from experience. And I also read every last one of the articles that gets posted here. I can see what's coming.
(((I don't understand how it's not easy to scan the Armer system. Put in the CCs and you're done. Or download it from the DB. I put the entire ARMER system in my 536, tweaked GPS settings, towers, etc and it took me a half hour at most. Took that long just because I was setting up GPS for how I wanted it. Default settings will let you scan right away.)))
Well first, it must be nice to have such an expensive scanner. Congratulations.
Second, you may have found it very easy to do, but lots of people won't. And lots of people will never even get the chance to try because the price for admission to the hobby in MN has just quadrupled.
There will be countless problems posted. You'll see. There will also be complaints about audio quality. You'll see.
(((Consoles are old and each county is responsible for radios and county enhancements sites. No county has to go to Armer...but it makes sense up here. MNDot pays for the towers and maintenance, you pay for your radios and fees to be on the system. Most counties have found it's actually cheaper than their existing system(s), plus the added benefit of being able to go across the state and still talk to their Dispatch...or go to Wisconsin and ride the WISCOM system as well. )))
Once again, you are listing benefits to users of the system not benefits to scanner listeners to which, there aren't many.
I'm not debating benefits to users of ARMER. I'm pointing out the obvious drawbacks to scanner listeners.
(((Phase II is coming, but not for a long time, that was already stated in the MNDot meetings minutes )))
Like you pointed out, it's coming. And that will be the end.
You never reach the end of the trail until you start down that path.
It's taken my county 8 years to start shopping for phase 2. Not that long if you ask me.
(((I know you're a gun-ho against trunking radio systems and cost, and sometimes I agree with you...but this is actually a good system and has already helped Interop with MN agencies.
I have not once said it was a bad system. I have not talked much about the cost and I haven't gone into the politics of it. I have simply stated that it is bad for scanner listeners, it spells the end of the hobby in MN and for the scanner listeners there and the ones that will never get to be, I shed many a tear.
If only this hobby was more like firearms ownership, where the powerful gun lobby fights anything that can get in the way of having or using a gun more difficult. If the NRA was looking out for scanner listeners, there would be no trunking at all. There would be no digital. There would be no narrowbanding. But it isn't. There's nobody looking out for scanner listeners. Nobody fighting to make it easier and cheaper to get into the hobby. Only the surety that the end will come and it will start with digital. Especially these statewide and regionwide networks. And that is regrettable and deeply unfortunate.
