RonnieUSA
Does anyone use this for searching a ranges of frequencies?
If so how well does it work?
I use mine all the time. I find that the wider I go the less sensitive it is or the less likely that it will stop on an active frequency, depending on the strength of the signal of course . I like to stick to about 20 Mhz max.
MB
MB
That's the problem I'm having it's not stopping on anything.
No Shift Box checked.I was having that problem once as well and I was told to make sure the "Shift" box was unchecked, which it wasn't. Unchecking it solved my problem,
MB
Yes the PPM is set correctly, I have 3 NXDN Systems I listen to every day.So if you select a strong frequency and test it in the manual mode to ensure that the signal is there, and then set the FM to scan say 500 Mhz either side of it, it won't stop on that freq? I am sure this is a dumb question but did you try to adjust the PPM?
MB
So I am just trying to understand, when you say you listen to them every day it sounds like you where using the FM and it just stopped or were you listening to these frequencies by manually selecting them?
MB
I'm just searching for new frequencies, I have the 3 that I listen to programed into a scan list.
So the FM was working and now is not working and on the same computer that it was working on?
If the is the case you might want to post your problem on the following link, the author JDow will probably get back to you with some suggestions real quick.
https://uk.groups.yahoo.com/neo/groups/SDRSharp/info
I left at default. = 0No offense but, did you set your 'minimum signal strength' ?
Try dropping it to... say -30.... just start clicking on the down selector and you should see a the horizontal yellow line start coming down the display... I typically set this just above the noise floor.
Thank You, I'll see how that works out.
Now it's working.
Hi all, bringing up an old thread here. I am using this software to scan the MilAir band
220 to 380....
I would say the scanning speed is reasonable, but would be nice if is went through the entire range much faster. Does anyone have any tips or tricks? I have pretty much eliminated all the birdies and random interference already.
cheers,
Jason
