Cut repeater antenna to TX or RX Frequency?
johndjmix
Probably a bit of a silly question for more seasoned people on here. Im using a TRAM antenna for a repeater - and have the cut chart in front of me. Do I cut the antenna for the transmit frequency or the receive frequency?
I would think transmit?
--John
johndjmix
Thanks ko6jw, im thinking of picking up a MFJ-259C. Sounds like a good unit from what ive read.
--John
KD2GSU
prcguy
+1 on tuning for the TX frequency. Usually an antenna you would use on a repeater should have adequate BW to cover both TX and RX frequencies, but hopefully it will not be so narrow band to notice any degradation on RX.
I've had a couple of MFJ antenna analyzers and they all broke, they are basically toys. In fact, everything I ever had from MFJ broke. I bought a Comet CAA-500 antenna analyzer and am very happy with it.
prcguy
--John
KD2GSU
ko6jw_2
Santa Ynez, CA
Comet CAA-500 is an excellent tool. Does not analyze complex impedance, but that's not necessary most of the time. Recently found it to be confused by other nearby transmitters. I was using it to tune a unicom antenna at our local airport and it was zapped by the AWOS transmitter located nearby. Not for use in strong RF fields.
Voyager
Yep. ALWAYS TX. The SWR is much more critical there than on the RX frequency.
