CDM 10pin to 8 pin adapter?
photoguy2
It's been brought up in the past that a 8pin mic should not be used on a CDM.
However, call me old, but I prefer the older large style of white mic.
So, has anyone found a 8 pin to 10 pin adapter? Is disassembling a 8pin and a 10pin mic and swapping the cables an option?
It won't hurt to use the 8 pin plug on the CDM's. It'll push the two outside pins up. Unless you plan on using the telephone style handset, you don't need them.
I've been using the 8 pin mics for years, no issues.
Certainly wouldn't hurt to swap out the cables, but I don't think it's necessary.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
I thought so too right up until Motorola sent an 8 pin desk mic along with a new CDM1250 two years ago. I called customer support who checked with engineering who said it is OK like that.
I do have a stock of both 8P8C and 10P10C RJ connectors plus the proper crimping dies for both. If anyone needed a cable changed or custom length remote head cable, I could probably help with that.
photoguy2
Interesting, thanks guys.
I was under the impression the shoving a 8pin mic into the 10 connector repeatedly would cause grounding issues.
SteveC0625
Nope, it won't. If you look at an 8P8C, there's a wide ledge of plastic where 9 and 10 would be. When you insert the 8 pin plug into the 10 pin socket, you're pushing plastic against the the two outboard contacts. No grounding problem there.
