TK-280 default squelch and sensitivity settings
wwhitby
Autauga County, Alabama
I've got a TK-280 that has had the squelch and sensitivity settings "played" with. I know it needs to go back to the Kenwood service center for a proper tuning, but thanks to my health insurance changing and some extra bills I had to pay, I don't have much spare cash available right now.
So, can anyone share the factory default sensitivity and squelch settings on their TK-280? I know it won't be the best option, but it will get me in the ball park and get me by until I can save up the money to send it to the Kenwood service center.
Thanks!
Warren
ramal121
Lots and lots of watts
Calif Whine Country
On a 280 you state two parameters.
Squelch is easy. In user programming you can set the default squelch setting the radio will take after a "hard" reset. This is when the power is removed or recovering from a re-program. If the tuning was diddled with, the way I set this is to enter squelch in tuning mode and run the slider down until the speaker blows open squelch. Then reverse to close the squelch and then move the slider five points up. Of course this needs the program software to accomplish.
Now receiver sensitivity is a little more complicated and I stay away from it as much as I can. In a nutshell, the 280 has a varactor tuned front end and you need to set the voltage swing to the varactor across the bandspread of the receiver. To do this you'll need a signal generator, a way to measure sensitivity (-12dB sinad) and go through all the individual tuning frequencies to insure the receiver is at max sensitivity from one end of the freq spread to the other. Not for the faint of heart and again requires the program software and the necessary test equipment.
There are no "default" settings, only those that each individual radio has as tested.
wwhitby
I understand completely. I guess what i'm asking is that if anyone can provide the narrow band sensitivity settings on their TK-280, it will at least get me in the "ballpark" so I can use the radio until I can save up to have it retuned. I know it won't be perfect, and may be slightly out of tune, but it will be better than i've currently got.
ramal121
Calif Whine Country
Understood. From my TK-280:
Squelch wide =174
Squelch narrow = 190
Sensitivity done as wide or narrow, doesn't matter.
Sensitivity test = 54 (160.0500)
Sensitivity low = 84
Sensitivity center = 54 (same as test)
Sensitivity high = 53
Good luck.
Colton25
Why does my 280 always seem like it's receiving a signal? The receive light is always green on every channel and when i use OST it turns to static like the squelch is open, it also makes this static noise on channels that don't have a decode QT/DQT.
Squelch wide =174
Good luck.
Muhlenberg County, KY
Trial and Error
Squelch setting may not be just right. I've had to adjust through trial and error myself with just the computer. Not all radios are equal in how the adjustment settings are set. You may have to play a little with the adjustments to get it right so that it doesn't receive unwanted interference and show a signal all the time.
