rugrat5288
- Joined
- Jan 1, 2013
- Messages
- 21
Can you remove a department from your favorite list? If so how? Thanks.
Scroll to the right and you should see an ALERT LIGHT column.
In the Sentinel Program? I see the column but only 2 or so are possible to make changes. The other boxes are not highlighted to use and choose that option.
I've never seen that greyed out. Are you sure we are talking about the same column? What is the exact system type you are looking at? Is this in the FL or preloaded dB?
it's in my FL list.
The Alert Light boxes are greyed out, but you can click on the cell. It opens a window where you can make your color and pattern selections. See screen shot below:
My issues was due to the fact you can't delete a department from the edit favorite list screen
