Hp hangs up after digital transmission
rugrat5288
My local police department hangs up the hp for awhile after each one of there transmissions. I receive static for varying periods of time as if the squelch is to high then it just returns to scanning . Any way around this? This is the only frequency it happens on.
phask
KZZV - SE Ohio
What is your squelch setting?
What is the system - state, county , agency - or a RR link.
rugrat5288
Tone is off on pc but when receiving the frequency on hp it displays nac517 in red under police channel 1
Voyager
If the channel does not have that NAC programmed, program it. You may have a weak RF source nearby on or near that frequency that is holding the squelch open. Programming that NAC in the channel should cure the issue.
phask
KZZV - SE Ohio
Good thinking - think my brain is dead. Been in Freescan and a couple 996's for too long :)
rugrat5288
Well it seems cured now with the squelch on 4. I will program the tone tomorrow just to see and report back.
rugrat5288
I went back on to the pc and added the tone. At that time I also noticed that it was set to nfm on the frequency rather than fm. So far so good back at a squelch setting of 2. Thanks for the clues to clearing that issue up. I hope that fixes it.
mharris
Columbus, OH
My HP-2 gets a squelch tail once in a while on Motorola II systems. I don't think the HPs decode the end codes like the T/XTs do.
My HP-2 just started with the squelch tail on Columbus Public Safety about a week ago. It's very strange because it has never done this in the month or so I've owned it up until now. Very frustrating. My HP-1 started doing it after a few years of ownership. Is there a filter wearing out prematurely?
W8RMH
Feed Provider Since 2012
I think it is something with the system itself, not the scanner. Mine does it too and only on this system. You can try turning the squelch up a notch.
mharris
Columbus, OH
I did try turning the squelch up but it makes no difference. But thanks for the response. I guess there is nothing that can be about this done for now.
