Even since the narrow-band compliant rules went into affect January 2013, many dealers and 2-way radio shops have been dumping older radios. If you have time and patience to search, many used portable and used mobile radios can be purchased for about a 80-90% off their original price. High quality 2-way radio gear with many models carrying the Part 95A certification. Accessories and parts are readily available too! This includes OEM and aftermarket.
Kenwood TK-360G 1-4 watt 8 channel (will tune into the ham band 70 cm)
Kenwood TK-372G 1-4 watt 32 channel (alpha-numeric display) (70 cm amateur)
Kenwood TK-370G 1-4 watt 128 channel (alpha-numeric display) (70 cm amateur)
Kenwood TK-860 25 watt 32 channel (LCD Channel display only)
Kenwood TK-860G 25 watt 128 channel (alpha-numeric display)
Kenwood TK-880 25 watt 250 channel (alpha-numeric display)
Kenwood TK-8180 25 watt 250 channel (alpha-numeric display) If "scramble" feature is
available, then Part 95A certification is invalid for this model.
Keep in mind that there are a extensive list of portable and mobile radios in the Vertex and Motorola line that are capable of GMRS, business, and Amateur Band services as well.
