You need to know none of that.
Let's start from the beginning - this article from our wiki (links are always blue, by the way) has links to everything you need to know to use these DMA based scanners, including starter articles on trunking...
Program your DMA Scanner - The RadioReference Wiki
Swanton, I see, is in Garrett County. I'm assuming this is the system you are trying to copy...
Garrett County Government Trunking System, Oakland, Multi-State - Scanner Frequencies
We have only a little information on this, but it seems that there are 4 sites, with only a few freqs. You must program these in exactly the order of channel number (called the LCN - see the number to the left of the frequencies?) for trunking to work properly.
Start by reading over the various links in the above article, and obtaining a USB cable. Download FreeScan (as linked in the above article), and you'll be ready to start.
Once that's done, other users can send you file(s) to get you over the hump
Mike
