The pre-amp will not harm your scanner and it *may* improve reception. There are a lot of variables at play, so the only way to tell for sure in your situation it to try it out.
I own both the Uniden HP-1 and HP-2 and exclusively use them to monitor activities on the local sites of a large, regional 700/800mhz trunked system. Sometimes I want to monitor activity that is not carried on my local sites, so I need to monitor remote sites which introduces the need to use an outside antenna. I also needed the antenna to be above the roof, since the remote sites are not line of site to ground level and I have tech-shield roofing to compound the issue.
I live in an antenna restricted neighborhood, so I have to use a compromise antenna for this purpose, I chose to place a center fed 1/2 dipole vertically inside a vent pipe. This meant a long coax run, but the remaining space I had drilled through the wall stud would not allow another LMR400 cable. Faced with an extremely difficult drilling situation vs. using smaller coax (which I already had), I decided to source a low noise, narrow bandwidth pre-amp to be mounted up by the antenna.
Using the RF Power Plot function in the Homepatrol Extreme option set to the remote site's control channel, I bench tested the effectiveness of the system. I made a short, Youtube video to demonstrate the effectiveness of this configuration. I turned on the amp about halfway into the video. You can see and hear the night & day difference. Link:
https://www.youtube.com/watch?v=ZwdLujWR6L8
Below is a picture of my antenna garden (it’s hardly a “farm”
. Not a peep from the HOA in the years it has been there.
