NX-800 no audio on transmit
cbrrider06
Hello guys I need some serious help here. I have a NX-800 radio that will not pass audio on a digital channel. I will receive audio though. All the radios that I use have the same firmware on them. When I key the mic and talk no audio will pass through the repeater or on a talk around channel, but the signal strength indicator shows on the receiving radio that it is there. Also on a analog channel everything works fine. Everything is programmed exactly the same. Any help fixing this will be greatly appreciated.
motomeso
Ontario
Have you tried a different microphone? We use NX-800 and NX-820's in my field extensively and I have seen many KMC-35 fail with exactly what you are describing.
cbrrider06
Yes I have switched microphones. I have tried about everything I know to do. This is about to aggravate to crap out of me.
racingfan360
Have you tried re-blowing the firmware onto the radio that's giving you issues?
Have you tried reading the CPS off a good radio and re-writing onto this radio (Yes I know the programming should be the same, but sometimes it errors)?
The only time I've seen this is when one portable is slightly off-tune/off-frequency - only evident in digital not on analogue.
A couple things to check:
Make sure encryption is set to off. If it's set to on with the radio that doesn't seem to transmit, the signal level meter will show a signal on the other radios, but the audio will not necessarily pass.
Make sure the narrow/very narrow is set correctly for each channel.
Make sure your RAN code is set correctly.
This sound more like a programming issue than a firmware issue.
