Orion Questions
FDRadioguy777
I am fairly new to the remote mount Orions. Can someone please tell me how much power an Orion radio needs. I am looking at hooking up a remote mount Orion and have a few questions:
1. The yellow wire on the remote mount cable, does that hook to the positive terminal in the battery?
2. Will a car battery trickle charger provide too much power to radio and the control head. (I just wanted to power it up before I mount it permanently and I do not have a power supply)
Thank you for anyone who can assist me.
rescue161
KE4FHH
Hubert, NC
The yellow wire is suppose to be hooked to "switched" power, so when the ignition is turned on/off, the radio will turn on/off.
A trickle charger may not be enough power. Of course, it may be enough to power the radio on, but transmitting using said trickle charger will not provide enough power.
FDRadioguy777
So if I wanted to just turn the control head on with the knob would I hook the yellow wire to the positive terminal?
harrisradios
If you are not using the ignition you do not have to hook the yellow wire to anything. Then the volume knob acts as the on/off switch.
