IC-F5061
RADIOGUY2002
Chicago Burbs
Okay, im curious with this particular model ic-f5061 will an ignition cable cause the radio not to power up. And if thats the case how do I get around it to fix it as it's not going in a vehicle.
Thanks an advance
12dbsinad
No. The radio should power up regardless if the ignition sense line is connected or not. It is programmable in the CPS for enable/disable ignition as well as a time delay, but whatever the setting it should power on with the on/off button if the main power is energized.
