Need help with PDW 3.12
jfhtm350
New Market TN
Cant get the dern thing to work.I have a tapped radio hooked to the line input on the sound card. I can run DSD+ so its not the radio or tap. However I dont know if the digital signal is a pager signal or something else. If I post an audio file of the signal, is there some way someone can run it through and see if it is a pager signal so I can start looking to see if my settings are wrong?
jfhtm350
New Market TN
I decided to try out the ACARS part of it and it wont work either. I can hear the ACARS sound coming from the scanner through the computer but nothing. I have a known ACARS recording so I put it on a tablet and played it through the line input of the computer and nothing.
I even tried all this on a Vista laptop through the mic jack (there is no line input) and still nothing. Its like the program is ignoring the soundcards. I've noticed the meter in the top right corner doesnt move at all. I read somewhere that it is supposed to move with static. I think I will try version 3.1 and see what happens.
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
It is definitely NXDN48. I had to convert from 44khz to 96khz so the raw audio was not optimal, but I could decode it.
TG 1401 unencrypted
TG 1102 encrypted
The first little bit of audio was TG 1401 unencrypted. Most of the rest was TG 1102 encrypted.
DSD+ lkes 48khz / 96khz wav files.
Code:
Sync:+NXDN48 TB DATA
Sync:+NXDN48 TB VOICE
RAN=3  VCall  Group  TG=1401  RID=14000  4800 bps/Half Rate  Clear  KID=0
Sync:+NXDN48 TB VOICE    e:1
RAN=3
RAN=3
Sync:+NXDN48 TB VOICE    e:6r11
RAN=3
Sync: no sync
RAN=3
RAN=3
Sync:+NXDN48 TB VOICE    e:11
   e:1
RAN=3
Sync: no sync
RAN=3  VCall  Group  TG=1102  RID=10088  4800 bps/Half Rate  Scramble  KID=0
   e:1
RAN=3
auto-muting encrypted voice
Sync: no sync
RAN=3
RAN=3
Sync: no sync
RAN=3
RAN=3  VCall  Group  TG=1102  RID=10548  4800 bps/Half Rate  Scramble  KID=0
RAN=3
Sync: no sync
Mike
n4yek
Newport, Tennessee
Jamie,
That is the Sevier County NXDN trunk system you are hearing.
1401 is the Gatlinburg Police talkgroup
1102 is Sheriff's encrypted talkgroup
Danny
jfhtm350
New Market TN
Oh. I thought I had run DSD+ on that freq but I cant remember. There are some more digital freqs in the paging band but they were inactive when I made a recording. I'll have to look around again. Well at least I know what that freq is. Thanks guys.
I downloaded pdw3.1 and still get nothing with ACARS. The meter in the top right does move but barely (from the 1st dot to almost the 2nd dot). I think I lied since it barely moves with v3.12. I can jack the volume all the way up and the meter wont go anywhere. When I put the volume all the way down, the meter is dead still. So it looks like the program is seeing the audio but it isnt high enough. I'm fixing to put the program over in the recycle bin and put a 10pass DoD erase over it. Hehe. Maybe I'll try another program.
jfhtm350
New Market TN
Well I figured out why PDW wouldnt work. You have to have both left and right channels hooked up to the descriminator. It doesnt work with just one channel for some reason. Maybe this will help someone else.
foxtail
Niagara Region Canada
Maybe your not setting something up right...disc. does work with sound card. Disc. tap is only one tap not two. You could try a stereo plug but most taps I have done are mono...meaning just one. Ring and tip. But then I do also run with a real com port and a 4-level decoder from back in the day.
jfhtm350
New Market TN
It started working after I wired my descriminator cable into stereo. It was only wired up on the tip. I dont think it was just a coincidence but anythings possible and it works now.
jfhtm350
New Market TN
I can receive flex signals with the tap wired to both left and right channels if thats what your asking. I didnt notice anything about frames but it seemed like it was working fine. I just use the program to verify the digital signal is what it is and thats all. Not really interested in the data since it kind of boring to me. Maybe someone else can chime in.
cg
Connecticut
It has been a while but I recall that Flex C & D require hardware slicer. Things may have changed but I thought there was some that you still needed the box.
chris
foxtail
That's what I thought. I use a real 4-level slicer on win 98 and Xp and see frames A, B, C, D. When I use the hackrf or rtl with vc software cable it only shows A, B. So it looks like your only getting half the decodes when using the sound card way and not the serial way.
