Our school district has a repeater system in place for custodial and maintenance operations. The repeater is a vertex 7000 with duplexer using a unity gain UHF antenna mounted at 80ft on top of the water tower on the high school property. We are having trouble receiving portable radios inside other district schools located (2) 1.5 miles away and (1) 3 miles away. Would an upgrade to a high gain antenna help receive the weak signals from portable radios?
Thanks,
Tom
Trying to second guess how a system is playing from a distance is like trying to predict which way a chicken will walk out in the barnyard. The real question here is can the portable radios hear the repeater? The repeater has more power out than the portable radios. So you have an unbalanced system to start with. If the portables have no problem hearing the repeater at all the schools, then another solution should be considered. Maybe adding some voter receivers to the repeater is part of the solution.
A higher gain antenna would help. But there are other issues and factors that come into play here. Like what is the path between the repeater and the different schools? Is it flat and few trees or is it hilly and a bunch of trees? What is the construction of the buildings? Is it cinder block , brick, or poured concrete with re-bar? Need to know what those school building walls are made of.
Now consider this. The higher the gain of the antenna, the lower the far field lobe from the antenna is. So knowing what the ground is doing out away from the water tower will determine just what you might need for an antenna. If you plot out the location of the schools from the water tank, it will give you an idea if an omni antenna is the right choice, or is a directional antenna the way to go.
Now that I have come up with a number of questions and some possible solutions, you need to do your own homework. It may take a combination of changes to make the repeater system play the way you need it.
One question I haven't asked is what is the size of the antennas on the portable? Are they the short stubby antennas that are only a couple of inches high, or are the antennas 6 to 8 inches long? If your using the short stubby antennas, get rid of them and put the long antennas on the portables.
