HT1250 programming question's
RadioChief55
I been programming my HT1250 and have it doing everything I want except for 2 things.
1) I can get it to do the Start-up self test beep. What is it called, and where may I find it in the CPS?
2) I want the MDC to ID on the screen. I have the Display Decoder ID checked in the MDC system 1 of 1 tab, but nothing happens.
Any help would be appreciated, I a search in RR but didn't come up with anything readily available.
John
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Radio Configuration --> Alert Tones tab --> Power Up Tone Type. It's a drop down with three choices: Disabled, Normal, Musical
For MDC ID to work, the transmitting radio has to send the code to your receiving radio.
In the CPS, in the Personality where you want to have MDC ID work, you must assign the MDC system to the receive side before it will work. Conventional Personalities --> (your choice) --> Signalling tab --> Assign the the Rx system with the drop down menu.
Search tags: The Professional or Waris Series of radios includes:
HT750 HT1250 HT1550 EX500 EX600 EX560 EX650 PR860 CDM750 CDM1250 CDM1550 HT1250LS+ CDM1550LS+ CDM1550LS
It may be helpful to search using wildcards. If someone asks a question about one model,
the answer usually pertains to most, if not all. They are all programmed with HVN9025 CPS.
RadioChief55
Steve, with your help I was able to get the MDC ID to work.
The radio still wont beep on start up. I attached a picture of the way I have it configured, any ideas?
John
SteveC0625
John
Check Radio Configuration --> Basic tab and make sure that Disable Alerts is set to None.
Other than that, I see nothing in the CPS that would block Power Up Test beep.
RadioChief55
Steve, you were on the money. I have it working just the way I want it thanks to your help. Are you as knowledgeable with XTS 1500's as you are with the TH 1250's? I have a few scan group questions for the XTS.
