CDM 1250 External Speaker Question
elmer166
Rochester NY
Hello,
I have a CDM 1250 radio, programmed & works great. I bought the external speaker adapter, plug it in and no audio for the external speaker, only the main speaker on the radio. Do i have to have it programmed to use the external speaker and not use the internal speaker?
cmdrwill
So Cali
"Cable 62 Motorola CDM CDM750 CDM1250 CDM1550 Recording Adaptor "
Wrong cable.
BTW, the proper connector comes with the external speaker for the CDM series radios.
Pins one and sixteen.
elmer166
Rochester NY
I am new to mobile radios, only using scanners in the past.
What I want to do is use the CDM 1250 for my online scanner that I currently use a scanner for. I was told this was the correct cable to connect the radio to my computer then to my online scanner.
Tried searching and found something about pin 1 & 16 but the person who programmed the radio does not know. Going to another place tomorrow and will hopefully get it to work.
Wait,
Do you want an external speaker, or an external low level audio output to feed your computer?
Two different things.
Your post heading says "External Speaker Question".
On the CDM's, the SPEAKER output is on pins 1 and 16. This is amplified audio for feeding an external speaker, much to high level for feeding a line input.
Pin 11 is "flat RX audio" and is listed as "partly" programmable. Pin 7 is the ground.
You need to choose the correct output for what you want. You can use both outputs at the same time, if you want, 1 & 16 feeding an external speaker and 7 & 11 feeding your audio input.
Depending on how the radio is set up, you might need someone to check the settings in the programming. I don't have my programming computer here with me, but I could take a look tomorrow.
elmer166
Rochester NY
You are correct. I am new to radios. I figured like a scanner if you plug in a cord it will disable the speaker and be able to be connected to the computer. As I am finding out, it is not that easy to make it work.
I am going to a different person tomorrow to hopefully get the radio programed correctly.
Thanks for your help.
If you hook up an external speaker (or even the "flat audio") connection on the rear, it will not disconnect the internal speaker.
The "flat audio" output isn't altered by the volume control on the front of the radio, so if you want to hook up to your computer and just turn the volume down on the radio, that'll work just fine. The flat audio won't be affected.
Front volume control does control the external speaker, however.
cmdrwill
So Cali
What he really wants is Filtered Audio on pin 11. And it is not affected by the volume control.
And that is close to line level.
Skypilot007
Medford, NJ
I think he really wants both. Just add two more wires to the cable you bought and connect them to pins 1 & 16 of the connector. Those will run the external speaker. Connect the pre-wired connector for your audio feed to a computer. To disable the radios internal speaker you have to remove the control head and unplug the speaker wire from the speaker.
elmer166
Rochester NY
I got it to work. Thanks for all your help.
The problem I have now is the low audio.
Am hosting my online scanner using this radio.
800trashman
Can I ask, the "cable 62" mentioned above, will it allow me to still listen to the original speaker, and plug the radio into my digital recorder to record clean audio? I have a CDM 1550ls+, looking to record clean audio from it into my digital recorder with normal 3.5 jack in. Thanks
Yes, that's exactly what it's for.
That's the item you need, then. It will allow you to record and not interrupt the front speaker. The volume control on the front of the radio will only control the speaker(s), not the output that this cable uses.
