I am a little confused. Should I put it in as Motorola 800/900 or as P-25? Thanks!
MOT-800/900, however, After March, You will need a P-25 Phase II scanner. All MARCS users are going to MARCS-IP.
Can I get away with monitoring MARCS IP as long as it is on Phase I? I ask since I have a PSR-500. Thanks!
This where I got confused because the way I (mis)interpreted your statement I thought that they were gonna jump over from Ph-1 to Ph-2 right off. Well, I guess I have a lot to learn! lol!Ohio MARCS are switching to P-25 IP system with Phase II capabilities.
There is no definite word of when (if ever) the switch will be made to a phase II. Most credible sources say it is years away.
So your PRO-106 will be just fine when the switch is made to MARCS IP.
They are jumping to Marcs IP which is CAPABLE (key word is capable) of Phase II.
That doesn't mean that they will be using Phase II anytime soon (if ever). It just means that the Marcs IP system has that capability.
Just like I am CAPABLE of showing Brittney Spears a really, really good time!! Doesn't mean that will happen though.
