I have recently assumed a position on my local county's tv board which operates a number of TV translators in our area. Since I am the only board member with really any technical knowledge let alone radio experience (via amateur radio), I have been put in charge of our communications.
We (the TV district) is currently licensed for two frequencies, 1 repeater, 1 fixed base, 1 control station (6.1 meter rule, which I guess pertains to the maximum height of allowed antenna for this station), and 50 mobile stations. From what I can tell so far (I have yet to be able see any of the equipment) we do not have any narrowband compliant equipment (radio systems hasn't been used in years), the fixed base equipment was removed from the listed location years before, and subsequently became "lost". The control station as far as I can tell was at least at one time located with a radio tech who was contracted for a time, thought he is no longer in business. The repeater doesn't appear to be on, and may have suffered the same fate at the fixed base radio as it doesn't appear on current inventory lists for the location when it should be installed. Unfortunetly, due to weather, I'm unable to get to the repeater site for several months unless the need arises to take the snowcat up there to fix something else. And from what I understand, the mobile radios (3 of them) are late 80's to early 90's vintage Motorolas, probably 16ch maxtracs, so I am not sure the radios will be narrowband capable.
Im looking at putting a radio system together from basically scratch that will basically be used 4 to 6 times per year maybe. All of the radio sites are (theoretically) covered by cellular based on carrier coverage maps. With that in mind, do you think it's feasable to rebuild the system and make it compliant with FCC narrowbanding? While I believe the radio system should be rebuild and not have to rely on the cell network, I'm having a hard time justifying to myself that the costs would be worth it to the board and ultimatly to the taxpayers who fund the board thru their property taxes.
In essence, if you're in my shoes, do you spend the $$ on rebuilding the system or get a few cell phones?
