Looked it over haven't found anything for Immigration & Customs Enforcement for Tampa. Still listening to 168.850 and haven't heard anything as of yet.
When I scan the VHF Federal frequency band all I pick up is my local VA hospital, CBP & DEA when their active. I think the ICE went silent or went to a different frequency.
DEA on VHF in Florida? I thought they were still on UHF analog.
As for ICE, they're still on the same network they used to be on, CBP's, at least for now. But I digress, most stuff is on simplex tac and a lot of encryption being used.
What frequencies do you have for ICE in Tampa? Maybe I can help ID what you have.I scanned the ICE frequencies I have in my scanner didn't hear anything at all.
[/URL]
Here are the frequencies I have:
Tampa ICE - 168.850 PL 151.4HZ
163.7000 - I had a hit a few times on this channel and found via Google it belongs to ICE.
I have some other frequencies I programmed in for ICE but these are the only two I have found that I picked up.
163.7000 is exclusively ICE
You need to incorporate the NAC or PL with the Frequency, use will vary by Region.
I've heard ICE, CBP, BP, FIO, NPS, and FBI all on 163.7000
Both of those frequencies were part of the old analog Border Patrol system in the Tampa area. They have been taken off the air as of last fall. It is very unlikely that ICE units would operate on those frequencies. ICE would normally operate on the old analog CBP system throughout Florida.
What call signs did you hear ICE use? If you heard a three digit unit number, that would have been the border patrol. ICE Would have used four digit ID numbers prefixed by a letter.
Now Border Patrol, CBP OAM/OFO and ICE are all on the same new digital CBP system.
When I have it on NAC search on 163.700 I get 156hz or 293hz depends on the day so I guess they were using different NAC codes that is why I have it on NAC search.
PL = aka Analog is in Hz
NAC is P25 Digital and not in Hz
The voices I heard on 163.700 were 4 digit numbers I can't remember the number the center and agent used at the time sorry about that. By chance do you know the new frequencies ICE would use? I pick up 169.600 NAC 303 with full signal with clear auto transmissions and sometimes encryption
