brandonoh777
I am quite pleased with my 1st antenna build (VHF 1/4 wave ground plane) now I want to try an HF long wire type. I have my VHF ant. up about 35 feet on a home made metal conduit/pvc type mast on my apt 2nd floor balcony (not a lot of room to work with) the HF might be a lil more challenging as they tend to be much longer!! I do have a tree close and I might be able to feed some fishing line and sinker up over that and pull the wire up into the tree top? As so that kind of antenna and what to build it out of and the issue of a balun are my main questions. I have done some research on the web and youtube and most seem to be fairly simple vertical wires or horz. dipole types dropped into an inverted V With my space limitations the vertical type might be the best set up for me. Some say just 18 gage or so braided seeker wire can be used? cut to the correct length for a half or quarter wave. My target for now at least is the HF air band (I would love to be able to pick up some of the north Atlantic HF over water aircraft transmissions (from central Indiana) if that's even likely with this type of set up using an RTL/SDR dongel. And as far as a balen goes I am mostly clueless at this point still doing some research on that. what do you all recomond?
thanks Brandon
I am useing the ham it up up converter to get into the HF area with the RTL/SDR dongel
thanks Brandon
