Laird CRX-150 instructions
Tulsa
That antenna appears to be identical to a Ringo Ranger, which is a design that has been around for 30 years. Search Ringo Ranger and you can find instructions on setting the length to a specific frequency range.
prcguy
Its not just identical to a Ringo Ranger, it is a Ringo Ranger. Laird bought Cushcraft and the Ranger version has been around for about 45yrs.
prcguy
Voyager
+1 - identical to the RR only tuned a little shorter for the commercial band. The instructions would be the same for both. If you can only find the RR instructions, take an inch or two off the radiator lengths.
wwhitby
Autauga County, Alabama
I was able to get the instructions from Laird. The tuning instructions for the ARX-2 cut off at 160MHZ, while the CRX-150 will go up to the end of the VHF-hi band.
