Eugene
Greetings. I recently went to do an upgrade to my 996T. I went into the upgrade screen by cutting the power on while simultaneously holding the required keys. A message came on that stated I needed a registration key before applying the updates, so I unplugged everything and went to the Uniden site and it stated I needed an ESN and Checksum number which I needed to get off the screen. When I went back to the scanner however and turned it on it just flashes a blank screen. In reading further I see that you should not interrupt the process once started. Have I turned the scanner into a paperweight or can it be reset. Thanks in advance for any help.
Eugene KG4AVE
Eugene KG4AVE
