Hi, I'm an amateur amateur. My long lost brother was a ham, and enough knowledge rubbed off on me to become dangerous, so I thought I would ask the experts here.
I would like to modify a driveway sensor to be a mailbox alarm. Why you ask? Because I can't find any offerings with sufficient range. Although my house is only 300ft from the box, it's not line-of-sight, there's a hill and a forrest of trees in between. I tried one from Radio Shack and it would sound the alarm maybe 1/3 of the time it should have. All the mailbox alarms I've seen seem to max out at 300ft. I might have seen a MURS one but it was pretty expensive.
The new driveway alarm unit I have, a Chamberlain CWA2000, transmits spread spectrum between 902 and 926MHz. The specs say that the range is 1/2 mile. The infrared sensor is housed in a plastic box and there's a single wire monopole exiting the box. It's about 3.25" long as measured from the circuit
board. I would be mounting the sensor at the back of an all-aluminum mailbox. Dozens of people in Amazon reviews say this works great as a mailbox alarm but I think most have a plastic mailbox.
several questions:
If I kept the antenna internal to my all-aluminum mailbox, how much would the signal be attenuated?
What would be the best way to extend the antenna out of the mailbox? If feasible I would like to mount a rt angle whip attached to the back of the box. I found a half-wave 916Mhz whip like this at Mouser. I could drill a hole in the mailbox back and use an bulkhead connector. The antenna has a RP-SMA connector. Is it just a matter of inserting the monopole wire into the hole in the center, or should I also ground the outer shell, circuit board, and mailbox? (Which is a lot more work.)
Any help would be appreciated.
several questions:
