Midland 13-898
KD2DXF
Nobody
Anytown, USA
I saw a post for a Midland 13-898. asking $25, so I'm thinking of getting it. I tried searching some, but can't seem to find any specifications. does anyone know the output power is on these. The person selling it has no clue what it is, all they know is that it powers on and off.
gewecke
Banned
Illinois
It's a cb. 4 watts should be the rf out, as all the other cb's. :wink:
73,
n9zas
KD2DXF
Nobody
Anytown, USA
73,
n9zas
These were manufactured back in the 70's old 23 channel CB. Now according to an advertisement from a 1973 magazine, it has 5 watts on AM, and 15 on SSB. :lol:
Did some searching on wikipedia, and i find this:
"The older 23-channel radios built under the old specifications typically had an output of around 3.5 to 3.8 watts output when measured at the antenna connector."
gewecke
Banned
Illinois
Matt, what Midland was doing ( and still do ) was marketing hype. Technically you can have 5 watts to the input of the final amplifier, but only 4 watts out to the antenna connector per fcc rules.
However on SSB the rule is 12 watts PEP ( peak envelope power) not 15 as they claim. :wink:
73,
n9zas
KD2DXF
Nobody
Anytown, USA
73,
n9zas
Thanks for the info. They sent me some pictures, and it comes with an SWR/Watt meter, manual and mic. Ill post some pics when i get it, and get it set up.
KD2DXF
Nobody
Anytown, USA
Here is a picture of it. Works decent. When I key the mic, I can hear the carrier on my other radio, and scanner, but I get no audio. So I took the Uniden microphone and tried it with the Midland, and same issue, carrier but no audio. When I tried the midland microphone with the Uniden, it wouldn't do anything. Both microphones are the 4 pin. The midland receives perfectly. Any places on where to start troubleshooting? Thanks.
Retroradio
Ontario
Had a similar issue recently and after verifying the mic pin-outs online, wired up a known good mic and solved the issue. Actually had a mic with a dead element.
KD2DXF
Nobody
Anytown, USA
Did you have a probel with this specific radio by chance? I thought it was weird that the Midland and Uniden have the same connector, but apparently did not work correctly. The Uniden mic works on the Uniden CB, but both mics would only send a carrier signal on the Midland..
kc8kek
Yeah check the pinouts for the mic...even recently, different manufacturers have had different pin functions, even though it is a four pin mic and it still fits in the socket. I don't know anything about old Midland bases, but it seems like a fair chance that could be it.
Look through some of the boards online, there's some info out there on these radios. Kinda limited even on SSB with only 23 channels, but you might be able to find a mod and get higher up the band if you're looking for a project, have some basic soldering skills....and patience
KD2DXF
Nobody
Anytown, USA
You were Right. So i quick wired up another test mic, unfortunately with same result. Carrier but no audio, which makes me believe the problem in internally. I used test leads between the Unidens audio/ground and the mic wires inside the Midland. And also a Motorola Desk Microphone wired according to midland pin outs. SO this makes me believe theres something internally going on. Im stumped.
Unidens Pin out for the BC645
1. Shield/Ground
2. Audio Out
3. Transmit
4. Receive.
Midlands pinout:
1. Audio
2. Ground
3. PTT
4. Not Used
Retroradio
Ontario
The pinouts on the new Midland are quite different than the older Midlands is what I found online. Also look at the actual pin numbers as charts vary from a front view to a back view of the connector.
I ran "Midland cb mic wiring" on google and the answer was right there as a chart.
Post your results, pls.
KD2DXF
Nobody
Anytown, USA
The pin outs that i listed above are correct, I tested them this morning with my wire testers. Seems the PTT clicks when the PTT connects to the Ground. Which leaves pin 1 as Audio Hot, and pin 3 as Ground. So with the microphones working correctly, this means the Audio problem is inside the Unit itself. I cannot find any diagrams of the insides of this anywhere, so I will attempt to E-Mail Midland, and see if they would have any insight.
Retroradio
Ontario
Other than test it did you verify the pin outs online ....old Midland vs New Midland mic wiring?
Anyway, best of luck with it. I am curious to see how it works out as my name indicates Im a fan of old radios!
KD2DXF
Nobody
Anytown, USA
Yes I verified the pin outs. I would love to see this working too, but I don't know anything about the interior circuitry to know where to start troubleshooting.
Retroradio
Ontario
Best of luck with the project. I only re-mentioned the pin outs again as I found a different diagram than what you mentioned. As you have apparently checked everything then its research time. This is the fun in radio...building dipoles and figuring out mic wiring......lol
Cheers from snowy Canada
KD2DXF
Nobody
Anytown, USA
This is the site that I looked at to verify...BellsCB.Com
If you found something else, please share
Retroradio
Ontario
in gGoogle I typed in Midland cb mic wiring. the first image on the left which (a mic wiring chart ) shows old and new Midland wiring. It is from Walcottradio.
dispatch235
Central Missouri
If it has a "click" inside the radio when you key the mike, or jumper across the transmit pin and ground, it is a "relay-keyed" radio... many older 23 channel radios were. Sometimes the relay contacts tarnish and don't make good contact. I have taken the covers off the relays in the radios and used a "burnishing tool" to clean them with success usually, though sometimes temporarily. I ran several different Midlands back in the day, they were fairly durable radios. Make sure the PA switch is not set to PA also, as this setting will bypass the transmit audio the PA output jack on the back of the radio. If I remember right, there were several pinout versions for Midlands, and most had 4 prong plugs.
dispatch235
Central Missouri
"And also a Motorola Desk Microphone wired according to midland pin outs"
Motorola equipment is a breed of it's own... if it is an old Motorola cb desk mike it probably was amplified and got its power off the radio...i doubt if it would work on a Midland... if you can find an old Turner Plus3 desk mike they sounded great on Midlands most of the time
Retroradio
Ontario
KD2DXF - If you dont mind my asking , how are you doing with the radio? Its always good to see how a problem resolves itself in case it ever comes up again....
