When I run rtl_test, it "fails"....losing data. How do I fix that? "lost at least XXX bytes"
del1964 Member Premium Subscriber Joined Jan 7, 2010 Messages 659 Location Southern, IN Jan 26, 2015 #1 When I run rtl_test, it "fails"....losing data. How do I fix that? "lost at least XXX bytes" Attachments rtl_test_fail.jpg 30.9 KB · Views: 1,336
rbm Member Joined Jan 25, 2005 Messages 1,395 Location Upstate New York Jan 26, 2015 #2 Try a lower sample rate. (default is 2048000) Such as: rtl_test -s 1400000 (or even 1000000) Rich
PiccoIntegra Member Premium Subscriber Joined Dec 19, 2002 Messages 530 Location North Texas Jan 26, 2015 #3 The problem is, you're tying to run this in a virtual machine. Having that gaming rig, do you not have a spare hard drive laying around? You can eliminate many of the hurdles by not using a VM. ..and staying away from Kali
del1964 Member Premium Subscriber Joined Jan 7, 2010 Messages 659 Location Southern, IN Jan 26, 2015 #4 I thought I read somewhere about updating rtl-sdr library before gr-osmosdr? True? and if so, how is the best way to go about that? Uninstall in Pybomb and then reinstall rtl-sdr and gr-osmosdr or ????? sudo apt-get update kinda thing???
del1964 Member Premium Subscriber Joined Jan 7, 2010 Messages 659 Location Southern, IN Jan 26, 2015 #5 It failed at all sample rates. Gqrx "runs" but apparently it has to do with improper RTL - SDR settings/driver?
del1964 Member Premium Subscriber Joined Jan 7, 2010 Messages 659 Location Southern, IN Jan 26, 2015 #6 Btw SDR# and other bare metal installed SDR apps run great Just inside Virtual Box / Linux Mint something's not right with dongle comms
del1964 Member Premium Subscriber Joined Jan 7, 2010 Messages 659 Location Southern, IN Jan 26, 2015 #7 What is the danger of running GNURADIO on Windows 7?
del1964 Member Premium Subscriber Joined Jan 7, 2010 Messages 659 Location Southern, IN Jan 26, 2015 #8 Has to have Linux OS?
del1964 Member Premium Subscriber Joined Jan 7, 2010 Messages 659 Location Southern, IN Jan 26, 2015 #9 Do sample rates have to be multiples of 512? Options I get are numbers followed only by trailing zeros ...no odd numbers
