153.0725 Rptr out NFM & NXDN !!!
158.4225 Mobiles
It appears for this repeater at least Pafford is using NXDN (NexEDGE) conventional digital. So you can give a listen to confirm if it is digital or analog. Once you have it holler back and I will add it for Brandon. Also am unsure currently if they also have access to the RCTRS like Acadian does.
If they are indeed NXDN and not using encryption then the only way to hear em is DSD+, or get an NexEDGE radio and find someone that will program it for you. (That last I hate to recommend as essentially unless you get the permission from PAS your illegally accessing their system.)
