Bricked Motorola CDM1250
WatnNY
Knoxville, TN
I have no clue why the radio chose to do it to me this time, when I have programmed it before with no trouble. Anyway, I always thought the "eeprom error" message was fatal. Now today I see on eBay someone is offering service to fix it so the radio can be programmed again. $29.95 sure is cheaper than buying another radio - so is it true they can be fixed?
Here's the link to the service: Motorola EEPROM Error Service Repair for HT750 HT1250 CDM1250 CDM1550 Radios  | eBay
Mike
Skypilot007
Medford, NJ
You must have an old version of CPS. I had 2 CDM 1250 radios with the eeprom error. I believe using CPS R06.12.02 or newer will fix the problem. Chances are the guy on ebay is just using newer CPS and it will fix the radio. Only problem is when you get it back your old CPS won't read it or write to it. You should get some newer CPS so you can easily fix it yourself.
Watch out for the latest version as you will need an entitlement key to do wide band (25khz) channels. Some of the older versions of CPS that fix this problem are floating around out there in the wild. Shouldn't be to hard to find.
WatnNY
Knoxville, TN
Thanks Skypilot. I think I have found someone local who's going to look at it for me. The odd thing is I have programmed this radio multiple times, then this last time she beeped and hiccuped and I got the eeprom error. Makes me leery of the radio now!
Mike
giguchan
$uffolk County Long I$land NY
What is the latest version of CPS anyhow? I think I might be a tad behind... I did go through that TRAINING they made me go through. That was the last time up updated. The Latest I have is R06.12.09
