kas1263
I have read with regularity that some members have more than one or two scanners and was wondering why. Are they in populated areas that have more to listen to?
There have been pictures posted of RR listeners who have 8 digital scanners. There listening rooms are like a war room. These are just scanners that are inside, not in the car.
I have multiple reasons for running multiple scanners simultaneously. A large part of the answer has to do with how modern scanners (fail to properly) handle trunk tracking.
First reason is when there is a large incident in a large city. Before you know it there are a half dozen or more channels associated with the incident. I'll lock one scanner on law enforcement, one on fire, one on the media; just for starts. And while that is going on you don't want to stop monitoring the normal stuff.
Even a typical attempted auto stop can quickly spread to multiple channels. It will start in the city (the lead agency) and move to the county, involve aircraft (with their own co-ordination frequency) and then the CHP. Just as one agency drops off, the offender moves into another county where you need another set of frequencies to follow the hand-off (if there is one).
The biggest reason for me is something that would take a chapter in a book to explain. The quick answer is that you need one scanner dedicated to monitoring EACH trunked system you monitor. As soon as that scanner leaves the control channel, you'll miss a call. When scanning conventional channels, the scanner will stop and you'll only miss a portion of the call, so they can all be monitored by one scanner, until you want to lock onto something.
