So I'm having an issue with my coax setup. As shown in the attached image, I have 2 scanners and 1 antenna wired using a standard coax cable splitter. Everything works fine, both scanners are using the same antenna with no issues BUT one scanner is used to provide an online feed.
I want to provide a feed with the second one as well but when I plug in the aux cable to the computer, audio from both scanners cross over each other's feed. As long as 1 scanner is not plugged into a computer via aux cable, this issue does not happen.
Would a ground loop isolator solve this issue, or would I need a multicoupler?
