BrettL
Hi, guys. I hope I posted this in the correct place. I'm new to the forums. If anyone could help me it would really be appreciated. I have Garmin DC 40 tracking collar and the Astro 320 receiver. A simple battery replacement in the collar resulted in my 6 year old son breaking the patch antenna inside the device. This circomm patch antennas bandwith is 11.25kHz on frequencies 151.820MHz, 151.880MHz and 151.940MHz. The authorized bandwidth is 20.0kHz on frequencies 154.570MHz and 154.600MHz. It has the 5Khz deviation. Uses 2w of transmitting power. The radom that surrounds the antenna is cracked through to the small micro film that makes the antenna. I contacted circomm technologies in Tiawan about specs and purchase of this device. The communication was poor so I contacted Garmin GPS and was told by one of their techs that he had no information about the antenna but I could send it in for replacement. Why do this when I can replace it myself. One solder joint, a RF cable, and with the help of a razor blade I can remove the 2 sided sticky tape that helps secure it to the pcb. I'm having issues when trying to purchase this little booger. Where is a good reliable place to purchase this patch antenna? I would attach a jpg of the patch antenna but don't think I have right or it's not working. I'm the noob.
