HT1250 model number help.
RadioChief55
I was on this forum and on Batlabs looking at model number decoding. I'm trying to see how many channels the radio is and what frequency range it is. Here is the numbers AAH258DF9AA5AN, the 5 after the second AA should be the number of channels in the radio, I thing??? But it's not on any on the lists. Thanks John
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
John,
  • The correct model number is AAH25SDF9AA5AN, I believe, but I don't find SDF in any of my charts.
  • AAH25 standard for the portables in the Pro Series.
  • What you have as an 8 should actually be an S which makes it UHF2 450-527 MHz.
  • The D indicates a 4 watt UHF radio.
  • Where you have an F, the charts list C=No Display, D=Limited Keypad, H=1 line display. If the H is actually an F, then the radio should have a DTMF keypad.
  • 9 means it is programmable
  • AA means conventional
  • 5 = 128 channels
  • AN is the revision level
Take a closer look at the model number on the radio.
RadioChief55
I don't have the radio, it's a radio i'm look at buying. That's the number that the owner of the radio gave me. I'll have to ask for him to recheck it I guess.
SteveC0625
Double check the model number with him. The high split UHF is not that common, but if that's what you want or need, fine.
If I was looking at that radio, I would insist that the seller send me a good quality, well focused close-up pic of the entire label that is under the battery. That way, you have the model number and the serial number. Not only can you verify the radio from the model number, but from the serial number you can check to see if the radio is stolen and also determine the age of the unit. If the seller is legit, he won't balk at providing that for you.
