looking for high ALTITUDE freqs over nevada
mhscan
Scannerbuff999 Duplicate Account
Banned
what are the freq s used for the FAA high ALTITUDE used over Nevada
any idea that is where the u2s and Nasa birds hang out
kma371
U2's out of Beale use the standard Oakland Center freqs for the sector they are in. Heard them (Pinion 71) about 5 mins ago on approach to Beale.
There is no specific frequency I'm aware of other than ATC Controllers unless they are doing testing near Fallon.
737mech
Clark County, NV.
NASA U2
All of the NASA aircraft can be tracked here NASA::Airborne Science Program::Aircraft Tracker then you'd have to determine LA center or Oakland CTR or SLC Center. Based on what you see and where they are. Better to find the freqs they use for missions. 235.4 for starters. You'd also want the Joshua ATC UHF freqs for the Edwards area and ranges. And Palmdale Plant 42 as well.
2k1typeSH
California
Try:
296.700 Oakland Center
369.900 Los Angeles Center
364.800 Salt Lake Center
285.450 Seattle Center
The above frequencies are used for flight operations above 60,000 feet (FL 600), which is the altitude U2s operate at. Due to the fact that they are at extremely high altitudes, transmissions from these aircraft can often be heard from hundreds of miles away.
