Amtrak6904
Hello all, I do not know too much about radio installs so please bear with me if this is an obvious problem.
A group of myself and others work together in a photography business, and we recently decided to take our operations efficiency up a notch by renting a radio system. We are utilizing Kenwood NX800 mobiles at this time (total of 3 for now) on an NXDN system provided by Mobile Relay Associates here in So Cal. Two of us had our radios installed professionally by a business that does installs, and mine was installed myself. We all are experiencing one common issue though. Whenever we transmit, our radios are cutting out our scanners or creating horrible interference noise, but is only specifically on frequencies in the range of 450-512. This inhibits us from hearing things while we are talking which could be a serious issue on a long transmission. For my setup specifically, I am using a Uniden BCD436HP connected with a magnet mount antenna, a PRO106 with just a standard antenna, and a Motorola MTS2000. My NX800 is hooked up to a magnet mount antenna, and the other two NX800s are running off drilled antennas. I highly doubt it is the way they were installed because all three of them are having the same problem.
Any one have ideas?
Any one have ideas?
