For those who listen to the MOSWIN Troop F feed, I have received several reports of bad audio lately. I have isolated the problem as a bad front-end on the scanner itself (it's used, and wasn't taken care of by its' previous owner). I have bumped the audio levels on the PC to try to compensae for the radio's issues, but this will increase the noise level as well.
I have started an Indiegogo campaign to replace it with a new BCD996XT.
https://www.indiegogo.com/projects/...r-broadcastify-streaming/x/9816611#home/share
If enough money is raised with this campaign, I will replace the Boone County, MO fire/EMS scanner as well. It's working properly, but it's an OLD analog scanner without alpha-tag ability.
If you listen to these feeds (particularly the MOSWIN feed), please consider supporting the campaign for a radio that hasn't been beat to death.
