stingray327
For a HP-2 and a 436 I have 32 GB SD chips in them already. Will I see any differences or what kind of improvements if I replace those 32 GB chips with 32 GB 90 MB chips?
I have already done this for my 536HP and yes there is a improvement the best way to prove this is what I call the echo test use a 966 t or xt put next to a 536hp with same programing start with the original card 4gig class 4 or a 32gig class 4 I used the 32gig class 4 to start there will be an echo between the two because of the slow card slows the scanner down for recording next I went and got a faster card a 32 gig class 10 at 43 mbts a sec the echo was shorter but still there so I went and bought a new card 32gig class 10 at 90 mbts a second and the echo is very slight meaning faster is better and Uniden should say this in the owner's manual. The nice thing is that the cards are getting faster and the price cheaper.
When some of you are talking about speed, do you mean strictly load-time? Or do you also mean that the SD card will increase actual scanning speed when the device is running?
When I upped from the OEM 4GG SD to a 16 I noticed the -Boot Up- was faster,,Much faster..Its a SanDisk Ultra SD..Ive got a 32,but have yet to load it up and pop it in.
Ultimately Ill max it out with a 64GB SD..But not there yet..
Can you elaborate,Why do you say the loading time is faster..I agree it is,But I dont know why..
According to the specs in the user manual, the 436/536 scanners can use SD cards up to 32 GB. So you can't use a 64 GB.
Regarding reading and writing speed, that has to do with the Class rating. A Class 4 is rated at a Minimum of 4 MB/s. Class 10 is a Minimum of 10 MB/s.
Other factors impact the read and write speeds. Like file fragmentation. So if you do a lot of recording or make a lot of changes that are written to the SD. The data will fragment and the SD's R/W speed will slow down. In that case, to get the speed back reformat the SD and reload the data.
