I am trying to set up SDR#, DSD+ and UniTrunker by following the instructions here https://sites.google.com/site/policescannerhowto/
I seem to have the Signal Receiver configured OK.
I have gotten to the point of configuring the control receiver (RTL2832U+R820T dongle).This step:
"Set the Model to “Debug”, and select all three control protocols: P25, ProVoice, and VSELP."
I go to "Create a new receiver and select "Control". In the drop down menu there are a bunch of scanner hardware models listed (Uniden, Icomm etc) but I'm not seeing "Debug" That's as far as I get.
As a side note, When I hit the + in the receivers panel and the "Create a new receiver" dialog box comes up, there are the options "Signal" "Control" "Both" "Inline" and Debug".
As an experiment I tried selecting "Debug" because in the guide I am following, the example dialog box is titled (at the very top) "Receiver Debug" I seem to be able to configure it there as described but when I "go to the main UniTrunker options screen, click the Enable checkbox in the Listen section. There should now be two receivers listed under the Receivers tab. One control and one signal. Select each and press the play button." as it says to do, there is only one listed, not two. Any help getting this configured or any other pointers gettinging this set up would be much appreciated. My main goal here is monitoring a Provoice trunked system.
