EF Johnson 5100 powers off, then does not power on!
ad8g
Cleveland, Ohio
I have an EF Johnson 5100, verison 1.18.15. The radio appears to work fine, but when I power it down, it says "Powering Down," then shuts off. Then it won't turn back on unless I pull the battery and put it back on. The soft power-down option is NOT enabled.
Sometimes it'll even get stuck with the backlight on (but a blank screen).
Does anyone know what could have caused this?
It's an eBay radio, I don't know where it came from.
MTS2000des
5B2_BEE00 Czar
the early Version 1 5100 radios were very problematic. Sadly, they are no longer supported by EFJ.
You can try reseating the flex connectors from the controller board to the RF board.
I had a 5100 years ago that did exactly the same thing, or would act strangely when connected to an RSM, and require a battery pull to get the radio working right again.
