Can anyone answer this question?
I have these radios that operate in the FRS/GMRS frequency range. I am trying to modify it by attaching a 1/8th in head phone jack to be able to play music or whatever from my phone over the walkie talkie. Basically what ive done so far is just solder on in place of the microphone/speaker. I've tried both of the jacks pictured just to do it. I got it to work on some cheap walkie talkies that operate on a lower frequency but I can't get this to do the same thing. Can anybody help me or explain to me why this wouldnt work please and thank you!
Voyager
You might want to review FCC Part 95 before putting much more work into this project, as:
1. Playing music over either service is illegal, and
2. Modifying the radios is illegal.
Oh great...what if i were to create my own radio from scratch, how would i go about getting sound to play through an 1/8th jack? The sound would just be a voice
mancow
N.E. Kansas
They don't have microphone jack on them?
The microphone appears to be the small round hole where an electret capsule is located.
Citywide173
Attleboro, MA
First, I would follow the above advice, as it is not exactly legal.
As far as your question, what are you using to close the PTT circuit? Is the radio VOX capable, and is it enabled? Was the other radio you referenced VOX capable? I think this is where your issue lies.
Yes it is vox capable but I dont think it was enabled. and for the other walkie talkie Im not sure, there was not configurable settings or channels, they were a cheap set of kids walkie talkies. What exactly is VOX?
Citywide173
Attleboro, MA
It's voice actuation. When the radio senses noise above a certain level from the microphone, it closes the PTT circuit, allowing the audio to automatically pass. If you're planning on a constant audio stream, the components in those cheap radios will probably fail relatively quickly.
I dont want to use the cheap ones, they arent even the right frequency I want. Im not gonna have constant sound but i do need it to be able to transmit without the PTT button being pressed. So if VOX is enabled you think it will pass sound from the audio device?
Citywide173
Attleboro, MA
You would have to enable VOX, or wire the PTT circuit with an on/off switch in place of the current momentary switch so that you could switch the transmit as you needed it. You could just wire the circuit for constant transmit, but I would advise against it as it might cause harmful interference while unattended.
Once again, I am only addressing the theory of why it isn't working, make sure your application is in accordance with FCC guidelines.
mchart13
Kapuskasing Ontario Canada
Assuming this will be your "music" transmitting radio that will be connected to your cell, ipod... headphone jack.
You have your wires connected to the speaker of that GMRS radio, that won't work. You need to be connected to the MIC of the radio which is up a bit and to the right which has that black felt or rubber gromet around it. I think MANCOW was trying to tell you that.
Also yes you will need VOX turned on
Okay so i enabled VOX and nothing happened, I did notice though when i push the PTT to transmit i hear slight static but it also seems to pick up other noises like if i click or flick on the waklie talkie itself the click sound gets transmitted as if the whole walkie talkie is now a microphone. But voice does not get transmitted.
I thought the speaker output was the same as the microphone lol figured it was dual device...so i will check that out! My bad lol also thanks for pointing that out!
Guess what!? That worked lol I'm a DA...thanks for your help guys! I do plan on getting a license and everything for my device im just still in the planning and developing phase. But this is one step forward, thanks for pointing that out to me.
Voyager
I doubt the other GMRS/FRS users in your area will let you stay on the air long. Anyway, no sense in bothering with the license since what you're doing is illegal anyway. What's one more violation on top of the two you're already committing? Although if you use FRS frequencies, there is no license, so you're back down to only two violations.
An by all means enjoy your project until the FCC cites you.
chuck_e7
Grayson, GA.
I think the DA part is using any radio! Why not use a Bluetooth device and be legal?
