I picked up a VX-7R after looking at the various options.. the 6R wasn't quite what I wanted, the 8R I couldn't find at the right price, so I picked up a 7R with all of the accessories I wanted in one swoop in an auction for a reasonable price.
But I'm having some issues with some features, maybe someone who has used this radio a lot can help me out? I'd greatly appreciate it.
First off, I can not set date/time. No matter what I do, when I go back to the menu for it, it's reset. I've done it a dozen times, each time exiting with PTT, or the VFO knob, or.. or... etc. No matter what, 2001/01/01 etc. it seems to keep time so far as I can tell, but it's wrong. Like right now it thinks it's 20:08, and as far as I can tell it's keeping time right from that reference, but it's 18:47 right now.. I did a clean factory reset to test if I've messed anything up with programming, it still wouldn't set.
I can not use any Memory Groups. I use CHIRP to program, but I've also manually added channels to Memory Groups. If I hit MONF-9 to go into the Special Memory view, select MR Group and hit PTT it just beeps twice. In fact it beeps twice on all options in this menu, including BC, Marine, etc. I've tried in the main VFO, sub VFO, in memory mode, in VFO mode, etc.. Only option I can pick here is "Off".
Temporary skipping a channel in scan mode... The manual says that you can temporary skip a channel while scanning "during this scanning session" by hitting MONF-V/M on the channel when it's stopped on the channel to be skipped. It does set it to skip, but it's NOT temporary! It sets that channel to be skipped, I have to go into the Set mode and change the channel back to not be skipped.
Does the battery indicator not show on the LCD full time? In the bottom-right corner is where the battery meter is, it's not there at all for me. There is unfortunately one line on the LCD that's not working but it's up towards the top.
And now purely a curiosity.... What is the small hole above the 2/3 keys? The manual doesn't mention it.
Thank you for the help!
