bob-the-scanner-man
I'm trying to get my two Pro-96s working correctly. The majority of the time the scanner works fine. However, occasionally the scanner will miss traffic or just not pick anything for a long period of time. I'm assuming it's something set wrong or a missing frequency somewhere.
Also, I've noticed that for some reason the Center Point talkgroup for the Sheriff almost always sounds great on both scanners. However, almost all of the Birmingham PD talkgroups sound horrible. That doesn't make sense to me at all since they're on the same system. Seems like they should both sound the same, but they don't.
In addition, I've noticed that if I program in only the simulcast site frequencies then I start missing traffic from JCSO CP, but I pick up the Birmingham PD talkgroups reliably although the decoding is still pretty bad. If I program in the Palmerdale site and the Simulcast site then I pick up JCSO CP reliably but get almost no traffic at all from the Birmingham PD talkgroups.
What's going on here?
Both scanners have 800mhz antennas. Both are using DSP 1.4. Both have been set up for the rebanded system.
If I'm in the Pinson area what site or sites should I have programmed into my scanners?
