scosgt
- Joined
- Jul 22, 2004
- Messages
- 1,295
Now that I have had a chance to play with one for a few days, here are some findings:
1. The display is more blue tinted than the PSR-800 or PRO-18 (I have both). I have several, they are all the same. Nor a problem, I personally like the more white display better but it is fine.
2. There are a couple of firmware glitches, which will probably never be addressed:
a. The S meter does not work by default, and every time you change the card it will stop working. Just go into settings and click on DEFAULT, that re-enables the S meter (and of course re-do all your settings too).
b. On occasion when you turn it on it will ask for the band plan. USA of course.
3. You can copy your PSR-800 config by simply copying the CDAT files into the 668 directory. This includes V scanners. Everything seems to work fine.
4. The included antenna sucks. You may have better results with a Diamond 77 than with the Radio Shack 800 MHZ antenna.
5. The software is a little glitchy. It may not import all the control channels and TG's for some reason. If you are not hearing what you expect, compare your programming with the RR database. I had an error that was preventing reception of two systems. Once corrected, the radio works great.
6. They do come with 4 Gig cards, not 2G. I am able to run a 16 gig with no issues.
7. The build feels a little cheaper than the PSR 800. Different plastic. Just feels cheaper. But for the current price, who cares!
Hope this helps some new owners.
