Win500: Won't Interface
noobiest
watr ct
My Pro 600 is working well and not connected to puter in over a yr. I go and try to connect and download a new setting to try and remove a very annoying weather setting that overrides my scanning with alarms and lights, over nothing, such as 'This alarm is just a warning of a warning' So I was gonna ask on the Forum, about that, but just connected the cable and it did seem to connect together and work OK but wouldn't let me start the Monitor / Control properly. When I hit the Start button, It shows this strange box in the Screen Shot.. My Win 500 back ups are in folders and all work to open the logs. I opened a new template and downloaded from scanner and still nothing. Thanks for even reading this, any ideas?
rwier
Phoenix, AZ
Well, since you don't seem to be overly anxious about "Activity Logging" why not check "None" and see what happens?
RDGDigital
MD - Eastern Shore
Okay, this is just a guess, but in your screen shot the "Log History" section has a check for "To both" but the "Log/audio file directory" box is empty. It looks like you have it set up to log information but you haven't told it where to put the log file.
Like I said, this is just a guess. Hope this helps.
noobiest
watr ct
Great guess and thanks. I just went to no logging and the scanner display now works with software,
