1coin3lives
- Joined
- Mar 19, 2015
- Messages
- 7
Hi -
I'm getting pretty close to my wits end, so I thought I'd ask for a little help or advice.
I recently purchased a Radio Shack 668 scanner and have been trying to get the thing set up.
I've figured out the basics of programming the 668 via software and the radio itself. The problem is that I can't seem to hear a large subset of talk groups that I should be able to hear.
So far the biggest problem seems to be with hearing anything relating to Phoenix police. At first I was unable to hear anything at all in its parent P25 system (called RWC, or Regional Wireless Cooperative) but I think I've finally sorted that out.
As of this morning I can hear Surprise PD Dispatch, which appears to be part of the same P25 system (RWC) as Phoenix PD.
But still not a peep from Phoenix, nor anything else that's labeled as part of RWC. I've attached screen shots of the my scanner playlist showing Phoenix and Surprise in the same list, and of the RadioReference page that also indicates Phoenix and Surprise are part of the same RWC system.
I've "prioritized" the Phoenix PD talkgroups in my playlist, though that doesn't seem to have addressed the issue. I've also changed the settings for data decode thresholds (dropping it as low as 10), as well as
DSP level adapt (tried 52).
I've also switched to a roof mounted antenna.
Nothing at all seems to make a difference, which suggests to me that I'm missing something else in the programming.
I've attached screen shots showing the playlist with both Surprise and Phoenix PD, as well as the relevant parts of the radioreference listing for my area.
Any advice or suggestions would be very much appreciated!
