Baofeng HT and simplex repeater
magnumfan
Richland County, OH
I have a Baofeng UV-82 that I'm hooking up to the Argent Data simplex repeater. I'm having an issue I can't figure out, the Baofeng sometime switches from Frequency A to Frequency B when I transmit into it and then the simplex repeater transmits but I hear nothing. Also when this happens the orange and green light flash over and over on the repeater after the failed transmission. Any suggestions anyone? Very frustrated
w1wra
Bedford, NH
Just curious, did you ever get this figured out? This same exact thing is happening to me now.
w1wra
Bedford, NH
Interesting. I think you are on to something.
I do not have an adapter handy to try an external antenna, but if I disconnect the antenna and put the radio on low power (I know, not a great idea) it seems to work properly.
Time to recheck the junk pile for a female sma adapter. Will follow up when things are good to go.
popnokick
Northeast PA
By "simplex repeater" do you mean the transmitter and receiver are on the same frequency? If so you are going to have a very hard time making anything work properly due to receiver overload. A little more info about your setup is needed (frequencies, antennas, length and type of coax cable for starters).
Thunderknight
Bletchley Park
The kind of simplex repeater the OP is Talking about is a stored voice repeater. It records incoming audio, then when the transmission drops, it plays it back on the same frequency.
Denense/etc that affect normal repeaters is not an issue here.
popnokick
Northeast PA
Doh! Knew I should have had more coffee before I wrote that reply. Actually was going to include a comment about simplex repeaters and note that if it was a store-and-forward type repeater then RF is not the issue. Thanks for catching it, Thunderknight. So what is the problem? Another guess...
Does the UV-82 have dual standby, and or the ability to have one "receiver" in "channel mode" and the other in "frequency mode"? I've seen flaky behavior on one of my HTs (not a UV-82) when I transmit but have different modes (channel vs freq) in each display. It will switch from "A" to "B" and the next time I transmit it is on the wrong radio / frequency.
N8XOG
St Clair Shores Michigan
The cable Argent sells for Baofeng is wired for the Kenwood handheld radios. It just so happens that Baofeng uses the same mic wiring except for the UV-82. The UV-82 has upper and lower push to talk buttons. So does the remote mic made for the UV-82. The Argent cable can't deal with this and will confuse the radio. There is nothing wrong with your Argent. It's not overloading, It's not an RF problem.
Simple solution: use your Argent with a UV-5r. It will work fine, mine does.
matty909
Fontana, California
Make sure tdr "dual standby" (menu-7) is off and/or make sure tdr AB (menu-34) is on either "a" or "b" whichever line you plan to transmit on
KC9HI
Your UV-82 is working normally. When you press the top [A] [PTT] button, the top [A] display is automatically selected. When you press the bottom [PTT] button, the bottom display is automatically selected.
Standard external mics and accessories can only key up the bottom display. When the bottom display is keyed up, it become selected as described above. Only a dual [PPT] external mic can key up the top [A] display. So the Argent Data simplex repeater can only key up the bottom display of your UV-82, You must use the bottom display with your simplex repeater.
Reference for UV-82 Menus
Jim KC9HI
