I am having choppy reception from my local P25 phase 2 system. I am currently monitoring a single
CC. The tower i am receiving is only 2 to 3 miles away and have line of sight to it. I have a signal strength
of 5 bars, with the "T" solid indicator. When voice begins, I get a "D2" indicator. The audio is choppy and the "T" indicator flashes in sequence to the choppy audio. Once the audio stops, the "T" returns to solid.
Here is what I've done to fix the problem.
1. DSP - Changed up and down to different levels.
2. AGC - Turned it on and off.
3. ATT - Turned it on and off.
4. Threshold - Moved both numbers up and down.
5. Moved around to different spots. Went outside. Could see the tower.
6. Changed frequency options from FM to NFM and back to FM.
7. No priorities are set.
Thank you for your suggestions!
