Astro Saber CPS communication problem - HELP!!!
Kabul Afghanistan
I have the latest CPS software for the Astro Saber and I am trying to use it on a Durabook windows 7 64bit platform. I used the virtual windows xp 32bit to install and run the CPS. I cant get the software to communicate with the radio. I installed an older version of the CPS on a dif computer ( one I use to program Sabers). The computer read the radio so I know it is not the rib box or the cables. I can not use that version of CPS because it is to old for the code plug in the radio. My first thought is a comm port issue. Can anyone help me troubleshoot this issue?
PACNWDude
Astro Saber programming computer.
I have used my oldest computers for Astro Saber CPS programming. Including swabbing hard drives from an old Panasonic CF-72 into newer bodies to keep my old XP Motorola programmer running.
As the previous poster said, CPS likes XP. I tried virtual machines on Windows7 and Windows8, and eventually went right back to my old XP computers, Panasonic and an older Toshiba Tecra. Windows XP is the one that works.
For non-Astro Sabers, I use RSS and DOS on a very old Toshiba Satellite.
Some local radio shops keep old XP computers just for the pre-1998-2000 Motorola radios, since that is what works.
N4KVE
PALM BEACH, FLORIDA
I just sold a XP laptop to a guy I know with a serial port for $120. He was tearing his hair out between the Windows 64 bit laptop, & the USB/serial port adapter. Now he's my best friend. LOL.
tbendick
Nyc
Not going to read/write under win7 64bit. You can use the software under virtual xp and edit the codeplugs but thats it.
cabletech
Puget Sound
I have found and others have found, that the Saber software DOES NOT like to run under 64 bit OS.
Some times it will work okay under straight Win 7 32 bit, and other times using Win 7, you need to set compatibility for XP or use virtual XP.
BUT THE BEST WAY is to use a true XP machine 32 bit.
I also have a supply of Gateway 450 computers with a true serial port as well as USB ports all are working just fine, some have XP on them and some do not have any OS.
I have these just for the radio people that need a more capable computer for older software.
Contact direct at cabletech03@hotmail.com
