I'm getting ready to build my own 4 element yagi antenna, using the calculator on this website. 4 Element Yagi Antenna Calculator: i1wqrlinkradio.com
I'm using a 5/8" dowel, and 3/32" brass rod from hobby lobby. The main reason i am building this is because the county i like to listen in uses P25 simulcast, and my scanner drops everything like crazy. It is horrible how bad it drops literally every conversation. I hear a few words and then it drops. I am also using the stock antenna on my PSR-500 so i know that doesn't help either.
My 1st question is, would adding more director elements be beneficial? Or are the 2 directors good enough. If i wanted to add more directors, would i just use the same length that the 4 element yagi calculator gives me, and then space them out according to the calculator? Or does adding more elements mess with the rest of the antenna calculations?
My 2nd question is, i have a plethora of RG-59 75ohm cable, which i was planning on using for this project. Since this is only a receive antenna, and the cable length is probably only 6 feet, does it make a big difference that i am using 75 ohm cable instead of 50 ohm?
Thanks for anyone's input!!
