Tinkertek
I have the Home Patrol 2 scanner. I use it in my truck and the audio just wasn't loud enough. So I purchased a Pyle 15 W audio amplifier on eBay. It's so much louder now, but at the start of each conversation, there is an objectionable pop through the speaker. It does this as soon as the squelch breaks. It's tolerable until I get a very weak signal, in and out of squelch. Pop talk pop talk pop talk,
I used the headphone output (1/8" jack) and tied that to the amp input. I have tried adjusting both the scanner volume, as well as the amp volume. Thinking would be better with higher scanner volume and lower amp volume, but little difference to the popping sound.
Any thoughts on what I can do to remove that initial popping sound?
Thanks,
Paul
Thanks,
Paul
