Icom F3161 Scan List Control
ncrailfan
I have an Icom F3161DT and cannot seem to access my 2nd and 3rd scan lists that I have set up and only the 1st one is displayed. Is there something I need to set up within the programming software to get it to work with the side buttons on the handheld?
cabletech
Puget Sound
The answer to this is a little difficult. First off, need to know how you have the scan list(s) set up.
In most of the Icom radios with muliti scan list ability, they are only slaved to one channel bank, this means that list 1 is slaved to bank 1 , list 2 to bank 2 etc.
The software does not have the ablity to tell the radio to use different lists on a single bank.
Even if you only have a single bank radio with the ablity for muliti scan lists,you can only use one list.
ncrailfan
I have the following scan lists as follows:
1. AAR
2. Yard Channels.
3. HAM
rapidcharger
The land of broken calculators.
Lets start with the basics.
Long press the Scan on/off button. (press and hold for 2-3 secs until it beeps)
Channel up/down to select the scan list you want.
Press SCAN again .
Repeat the process to change scan lists.
Is that what you meant?
ncrailfan
Yes. Have the front P0 button programmed as Scan Start/Stop and P4 Side One Top as Scan/Add/Del/TAG
12dbsinad
Program one of your side buttons as CH UP. Long press the P0 button, then tap the CH UP button until desired scan list, then tap the P0 button to confirm. Make sure you are not scanning when you do the long press of the PO button.
